Old 02-02-2015, 05:12 PM
HIDs turning off then on
Cold windy night, my DDM tuning HIDs are turning off then on then off etc. Bad ballast or something else?
Old 02-02-2015, 06:58 PM
scoobymal's Avatar
scoobymal scoobymal is offline
Smile Re: HIDs turning off then on
I had this problem about a year ago - a new ballast cured it, try swapping them over from left to right.
Old 02-02-2015, 07:12 PM
I put my original Sylvania bulbs back in. The right side is not working so it could be a bad wire or connector, or my original bulb went bad. Anyhow it is too dark and cold to do anything more. One headlight will due for tomorrows drive.
Old 02-28-2015, 10:12 PM
ShaneHobson ShaneHobson is offline
Both of my HID ballasts have failed, but never the bulbs.
Old 03-01-2015, 05:35 AM
Turns out that I had a failing alternator which was low charging. The HID issue was the first symptom. The weird thing was I always got a strong start even on the day it left me stranded. I also had issues with my new radio turning off which have gone away since the new alternator went in. Before I realized I had a bad alternator I was blaming myself for bad soldering or pinching a wire.
I haven't put the HIDs back in yet (it's been cold!), but I think they will be fine too now that the alternator has been replaced.
Old 03-05-2015, 10:22 AM
SoobCrazy SoobCrazy is offline
SVX n00b
http://www.subaru-svx.net/forum/show...14&postcount=6
