Old 07-09-2022, 05:46 PM
Re: Lsvx-t
Originally Posted by wdb View Post
But stance.
But width!! Got 275s on all 4 corners. I had to cut out the rusted wheel arches anyway.
But in more news
God only knows when I'll get a chance to install it... been otherwise occupied
Old 07-09-2022, 06:06 PM
oab_au oab_au is online now
Re: Lsvx-t
What looks very,,,,,,,,,,expensive.
One Arm Bloke.
Tell it like it is!
Old 07-10-2022, 03:08 AM
Blacky Blacky is online now
Re: Lsvx-t
It's almost too beautiful to install!
Old 11-03-2022, 10:16 AM
Re: Lsvx-t
I finally found this thread, great work Tom! I see you are welding Al now, fun stuff to work with isn't it?
I cringed when I saw that aluminum intake manifold in the first few pics and was happy to see that you swapped in a composite intake. The MSD atomic intake can handle a decent amount of pressure, according to several of the Vette guys that run them w/ blowers in my area, if you ever decide to go aftermarket again. Are you running a Ebay turbo or name brand? How's the spool/lag on it and have you driven it enough yet to know if it is properly sized to your specific combo? I have my eyes on the G30-770 or one of the Borgwarner EFR 8374, but it seems like people actually have good luck with some of the Chinese clones these days.
Can you provide some more details on the new Nisan steering setup, how the 350Z rear cradle mounts in relation to the stock setup mounting points, aside from the fuel tank removal, and what wheel arches you found that fit? I have a set of 255/40r18's that I am trying to tuck under the car, came off my 07 Legacy GT-L, and was thinking that flares would look better than just cutting away offending material and painting the edges of the steel.
Looking forwards to the end results and I hope you don't run into thermal management issues. I used Swaintech for my C7 Z51 and their white lightning coating is legit.
blk 92' LSL w/ average mods
Old 11-18-2022, 08:47 PM
Re: Lsvx-t
Sorry, dont get on much. Ill try to address a couple things.
Im running a vs racing turbo which is basically a clone of a bw turbo. 83/75 t4 w 1.10ar. It spools quickly and power comes in pretty quick. Im on gate at about 3500-4k rpm which is a little early but its not a top end car so it fits the bill perfectly right now. Currently on 7psi but i will be pushing that up next season.
Cooling was an issue with the cheapo ebay fans i had. I have since installed a pair of spall 12" fans and that has helped immensely.
The steering is an sti quick ratio rack that has been depowered. The nissan steering column was a lot more work than its worth and the results have been underwhelming so far. It "works" but its not very good. Maybe the toyota column from a prius is better as it seems. Most epas conversions go this route. I may one day ditch it and get another sti rack and go back to hydraulics.
Wheel arches are just cheapo ones from amazon. Front fenders dont work but the rears are fi e for what i needed
Thanks for the interest. I am currently building a whole new wiring harness using a real fuse and relay box instead of all the inline insanity i started with. I get an hour in the garage every other week basically so it been a slow go. But i also have all winter. Spring time i want to get it dyno tuned and maybe run it down a drag strip to break my old record from damn near 20 years ago
Old 11-25-2022, 03:59 PM
wdb wdb is offline
dances with roads
Re: Lsvx-t
Thanks as ever for the updates and for sharing your imagination with the SVX folks!
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 11-28-2022, 10:24 PM
Re: Lsvx-t
Tom check this out
https://tssfab.us/product/ls-v8-gr-f...rH5BfpFMNUepIg
Old 12-18-2022, 08:37 AM
Re: Lsvx-t
Eventually, i may go to a tubular subframe but for now what I have works.
Here's a quick pic of my harness situation. Trying to limit the ise of butt splices so I have continuous wire end to end with new terminals wherever i can find them. Certain things like the gauge cluster i cannot find the correct terminals so i needed to butt splice those wires. The rear harness is complete, i need to run the front harness next. Once thats done i will actually need to work on a dash so i can locate my switch panel again. I mat even add sunroof controls but that can always be done later. As always progress is slow as the baby takes most of my attention.
Old 12-18-2022, 07:55 PM
wdb wdb is offline
dances with roads
Re: Lsvx-t
Anything is better than nothing. I have an acquaintance with a Mini Cooper in his garage that hasn't been anything but a place to put stuff for about 10 years.
Kids. Time sinks.
Old 12-19-2022, 05:24 AM
Re: Lsvx-t
Kids. Time sinks.
My brother had a 1970 1/2 Camaro Z28 with a 495 cu. in. McLaren engine sitting in his garage for 41 years in various stages of modification. At age 78 he finally sold it last year to a friend because he figured he'd never get it back on the street. Good call I'd say.
Old 02-22-2023, 01:03 PM
Re: Lsvx-t
Still alive. Harness is technically complete but I need to wrap it and zip tie it to the dash bar. The original harness was full of inline fuse holders and was primarily run through a battery cut-off switch in lieu of relays. That is all sorted now and I have proper circuit protection and switching done through relays. Almost all of the wiring connections are end to end crimped terminals except for the instrument cluster pigtail as I couldn't find the correct terminals for that.
Once the wiring is done I do intend on changing my fuel setup. The cell will remain but I want to go with twin in tank pumps rather than the single out of tank pump I am using now. It's just a better way to do it IMHO and will be less noisy.
I have picked up a few side jobs including getting the first ever EG33 powered by a holley terminator ECU for our fearless leader Chris. I have also agreed to try and get Halistan's supercharged EG33 running properly as he has had no luck finding a mechanic who is capable of finding his issues and resolving them. With these projects sparking my interest again I have decided to be more open to the idea of working on peoples cars again, just on a smaller scale than I have in the past.
Life is good and getting better everyday!'
Old 02-26-2023, 10:36 AM
wdb wdb is offline
dances with roads
Re: Lsvx-t
Wow great progress on the beast, and it sounds like good progress in life as well. Congratulations! My old red SVX had a manual gearbox mounting frame made by you. It will be fun to see neat stuff coming from you again.
