Re: Holley Terminator powered EG33?
Yes, Holley Terminator is cheap, but you'll probably end up nickel and dime-ing parts and converters to get it to work with the EG33 that you'd be better off with another aftermarket ECU that isn't primarily made to run LS engines.
If budget is the main concern, just go with a MegaSquirt as that's even cheaper than Holley. They even made a DIY PNP kit if you feel inclined to track one down to use since it has been discontinued. (DIYPNPN76-K is the part number)
1992 Dark Teal LS-L w/ 165k+ miles (traded ) Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
