Old 08-24-2015, 11:58 PM
ChristophCobb ChristophCobb is offline
Re: 92 SVX sway bar and tie rods
Originally Posted by EdWindows View Post
FYI, the Energy Suspension sway bar bushings linked above will NOT WORK FOR STOCK SWAY BARS.
Stock size is 17mm. The 22mm bushings that people are referring to are for Nevin's 22mm rear sway bar.
Go OEM for the inner tie rods and water pump. They cost as much or cheaper than aftermarket.
As for front endlink replacement, you can buy REAR endlinks for a 00-06 Mini Cooper and they will work.
Lastly, if going manual, hydro clutch is not that difficult compared to cable. The cable can also snap on you easily, and it's a $70 cable from Subaru.
Hmm. Thank you for informing me. I was not aware that was the case. I already have the bushing but I have not got around to purchasing the other parts I said I needed. Is there a swaybar I can get that will fit them or should I return them? As for the transmission I'm really not informed enough or have enough funds to even start considering that right now, but I do want to plan ahead and I do want to do it eventually. Currently just worried about it slipping between 2nd and 3rd gear when driving slowly.
Old 08-25-2015, 06:18 AM
processengr's Avatar
As for the transmission, you should change the fluid (dextron3 will work) and most important, disconnect the transmission cooler at the radiator and blow air into the outlet to blow out any debris in the screen on the inlet. This screen was present only in the 92, and is known to get clogged, eventually destroying transmission due to restricted flow.
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 08-25-2015, 07:37 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Unless someone is selling a Nevin bar or you buy one from Motorsport Warehouse, I'd return them and buy the 17mm bushings.
Also, if you buy the bar from Motorsport Warehouse, try to buy/make some beefier endlinks. You will bend the stock ones easily with the upgraded 22mm bar.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 08-29-2015, 09:34 AM
Transmission cooler advice noted. Thanks for the tips guys. As for the tie rods and bushings I'm beginning to get frustrated as to what I'm actually looking for. This is mostly due to my inexperience, but I've received multiple answers online and in person and all seem to be a little differant each time. At this point I'm considering taking the car to a dealership or shop and saying "have at it" .. gonna be way more expensive but I'll be honest, in regards to swaybar links, bushings, and tie rods, I have no idea what I'm talking about or looking for. Going to see if I can return those bushings I bought...
Old 03-29-2017, 11:00 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
most all that stuff is here too...
planetsvx.com
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
