Old 05-17-2023, 06:46 AM
Re: Technical Requests for Assistance.
I think you will find that sensor 22053AA020 is not available, that why we use the cam sensor instead.
Fits the hole, but needs rotating to get the plug on, a washer on the hold down bolt to hold it down.
Old 05-17-2023, 07:46 AM
Noriyasu Noriyasu is offline
Hi, oab_au
I checked partsouq.com again, and it certainly doesn't seem to be currently available.
I also checked compatible parts.
22053AA020
AIRTEX 5S1893
STANDARD MOTOR PRODUCTS PC203
22056AA030
WELLS VEHICLE ELECTRONICS SU4219
AIRTEX 5S1373
DELPHI SS10064
AutoZone SS10064
ACDelco 213-2409
STANDARD MOTOR PC180
STANDARD INTERMOTOR WIRE PC180
CARQUEST 71-4593
Unfortunately I haven't been able to find any of them available in a few minutes, but maybe they are still out there somewhere.
It seems that 22053AA020 is not available in Japan too.
I know many parts are already discontinued and no longer available, but it seems I learned one more thing.
Old 05-17-2023, 08:39 AM
I tried a little more
It seems that crank angle sensors and cam angle sensors are no longer available in Japan after 2019.
It seems that the dealer has a repair SVX using the crank angle sensor of the BH5 type Legacy.
However, the crank angle sensor is fixed with a tie wrap because the bolt fixing holes do not match (interfere with the cam angle sensor).
I'm glad if you can use it as a reference
You can find the source of the information below. It is written in Japanese. Please use a web translator if you want to read.
https://minkara.carview.co.jp/group/...i/bbs/5105503/
